1991 Honda CRX Idle Jumping
1991 HONDA CRX
DIZ808BOI
Engine Mechanical problem
1991 Honda CRX 4 cyl Front Wheel Drive Manual 106xxx miles
My idle had been jumping and i hate it. It warms up perfectly fine without a noise. After several minutes it then starts jumping 1000 to 1500 rpm. After the car gets hot it then jumps 1000to 2000rpm. I change my Idle air control valve, and that wasn't the problem i then went to a mechanic to check the problem he told me it COULD be the throttle body sensor. He was the one that told me change my Idle air control valve. But i don't think so, i ask him if there was a vacuum leak and he said no he don't hear anything. So hey if any one knows what might be a problem i would appreciate the help or some advice. Thank you so much. You can get in touch of me at dizisland808boy@aol.com
Mar 29, 2008 at 8:05 AM
BLACKOP555
  • 10,386 POSTS
try to unplug the TPS sensor and see if that calms it down a bit, post back what you find.
Mar 29, 2008 at 12:50 PM
