1991 Honda CRX Fuel pump not priming
1991 HONDA CRX
167,000 MILES • 4 CYL • 2WD • MANUAL
ZSILVA
I have a 1991 Honda CRX SI
The car sat for a long time without being turned on.
Now, when i try to turn the vehicle on, it tries to turn over but the motor will not start.
When i sprayed some engine start in the intake manifold, the motor turns on but only for a while.
*I figured this ment that it is a fuel problem on my hands.
I replaced the fuel filter (and the spark plugs just to be safe)
I gave it a try and still the motor will not turn over. I tried to prime the lines (by continuosly turning the key off then on) i releases the pressure bolt on the fuel filter, and there was 1) no pressure 2) no fuel.
I dont know what i should check now.
Dec 17, 2009 at 5:00 AM
F4I_GUY
  • 3,302 POSTS
Check your main relay on the left side of the dash.
Dec 22, 2009 at 1:21 PM
