Initially, my car began to lack power/acceleration. I suspected fuel problems, and changed out the fuel filter, pump and the tank (which was rusted out). Following repair the fuel pressure was restored (about 30 PSI) but the engine is running bad, seems like its continuously missing. The engine passed a compression test recently, before I replaced the tank. CPU only indicates oxygen sensor and EGR trouble. Any suggestions as to possible problem?
Jan 13, 2009 at 1:39 PM
