1990 Honda CRX smoke
1990 HONDA CRX
100 MILES • 4 CYL • FWD • MANUAL
HONDACRX1990
my car blows out smoke , like once a day or more
not all the time
and the performance is good
it leaks oil only when im driving it (there is no oil where i park it )
please help
thanks
Nov 13, 2008 at 3:21 AM
  • CAR REPAIR CONTRIBUTOR
  • 31,937 POSTS
Hi there ,
If the smoke is bluish, it will be oil smoke, and you will have a problem with rings, or valve stem seals & valve guides, Stem seals & guides will tend to only smoke first thing in the morning or when the engine has had a chance to cool. and it will clear quickly, rings will smoke more often when the engine is warm and will do it under most driving conditions, what are your symptoms?
mark (mhpautos)
Nov 13, 2008 at 3:26 AM
HONDACRX1990
[quote:b76b2ce411="mhpautos"]Hi there ,
mark (mhpautos)[/quote:b76b2ce411]
its the rings because it only does it when its running
but can it be the head gaskit ?
Nov 13, 2008 at 1:26 PM
  • 31,937 POSTS
Hi there,
If it was a head gasket problem you would get far more coolant leaking and this will be whitish smoke, also overheating, i would be thinking more rings.
Mark (mhpautos)
Nov 13, 2008 at 3:27 PM
HONDACRX1990
[quote:a416dd81d8="mhpautos"]Hi there,
Mark (mhpautos)[/quote:a416dd81d8]
yeah i think it is
thanks alot
by the way how much do u guys charge for that
Nov 13, 2008 at 5:47 PM
  • 31,937 POSTS
Hi there,
Sorry, but i can't really answer that for you as i am in Australia, so my prices won't be of much yous to you.
Mark (mhpautos)
Nov 14, 2008 at 5:16 PM
