1990 Honda CRX Rattle jingle when I accelerate
201,000 MILES • 4 CYL • 2WD • MANUAL
HARRY
When I accelerate (high or low gears) I often hear a rattling or jingling noise from the engine.
When I lay off the gas it stops. Also, it doesn't keep making the noise.
Wish I could be more specific.
Not sure if I'm shifting too soon? Rings?
Thanks!!
Harry
Nov 18, 2008 at 6:15 AM
DANIEL-CRX
  • 7 POSTS
it could be your header. check it.
Feb 12, 2009 at 5:35 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:78f8448531="Harry"]Noises problem
1990 Honda CRX 4 cyl Two Wheel Drive Manual 201000 miles
Thanks!!
Harry[/quote:78f8448531]
Hi Harry,
Check or have your Timing Checked. If it is out it will cause the noise you are hearing and since it does it more on acceleration it would lead me more towards the timing.
Feb 12, 2009 at 6:24 AM
