1990 Honda CRX Overheating and leaking coolent
1990 HONDA CRX
ZLEISEY
Engine Cooling problem
1990 Honda CRX 4 cyl Two Wheel Drive Manual
For my CRX when i start it up and it starts to get hot it will start leaking coolant, and when i look to check if under the radiator cap to check if it went down at all it didnt so im not sure were to start looking
Mar 6, 2009 at 9:48 AM
BMRFIXIT
  • 19,053 POSTS
Leaking from where ?need to find the leak
if its overheating and leaking out the overflow
have to check thermostat and water pump
other than that you have to start with coolant system pressure test to locate the leak
good luck
Mar 18, 2009 at 10:38 PM
