1990 Honda CRX brake/tail light
150,000 MILES • 4 CYL • 4WD • MANUAL
BJBAUER
The brake light hardly ever works even though the tail light in the same bulb does. The connector casing is rusty inside but I have cleaned the contacts and assume contact is being made because of the tail light coming on. The brake filament is in one piece so I can't work out why the light's not coming on.
Apr 7, 2009 at 6:51 PM
BLUELIGHTNIN6
  • 16,542 POSTS
If the tail light is working but the brake light is not working then I suggest inspecting brake light switch, located above brake pedal arm under dash.
Thanks for using 2CarPros.com!
Apr 7, 2009 at 7:33 PM
BJBAUER
Thanks for your prompt answer but the OTHER brake light is working so I imagine it can't be the switch.
Apr 7, 2009 at 8:54 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Okay, sorry about that. I did not realize you meant only one side. Since this is an intermittent problem with one brake light then it must be a faulty connection somewhere. I suggest first inspecting ground wires as these are the most common to cause problems such as this. If ground is OK then inspect the rest of the wiring and use a volt meter if necessary.
Apr 7, 2009 at 8:57 PM
BJBAUER
Thanks! Will inspect everything that I can see easily but have no clue about electrics really so hope it's something obvious!
Apr 7, 2009 at 9:45 PM
KHLOW2008
  • 41,812 POSTS
Just my 2 cents.
Remove the bulb and check the 2 terminals inside socket. Sometimes one would wear off due to heat.
Swap bulb with other side to confirm bulb is ok, visual inspection sometimes do not work.
Apr 7, 2009 at 11:50 PM
BJBAUER
caught me on my way to the car, so I'll do that too. Thank you. :)
Apr 8, 2009 at 12:31 AM
