1989 Honda CRX Unknown Idle or Fuel Delivery Problem
215,000 MILES • 4 CYL • FWD • MANUAL
KDCHERLI
My car will start and fun fine, but every time I drive it, the engine will randomly start revving up to 3~4k RPMs and will just sit there. Then when taking off, it's really jumpy until I get over 4k RPMs. As I start slowing down (stoplight, cars in front of me), the car will still continue to deliver fuel and run above 4k rpm, so I have to put the car into a lower gear or hit the breaks to keep from running into someone. While in neutral, the car will continue to spike around 3~4k rpms and the engine is running quite loudly. Then randomly it will stop and the car will idle perfectly quiet between 0~1k rpms. Car will run great a for a while, and then it starts up again. Please HELP! :) Thanks in advance
Jan 15, 2010 at 1:22 AM
KHLOW2008
  • 41,812 POSTS
Hi kdcherli,
Remove the air intake hose and check if any debris are stuck between the throttle plates.
Check if the throttle cable is stuck.
For the rpm to be revving, additional air must be able to past the throttle plates so you need to check for vacumn leaks as well.
Jan 16, 2010 at 9:47 PM
TIPPLE_1999
My 88 CRX did this to. My issue was solved by replacing the O2 sensor.
Jan 17, 2010 at 5:25 AM
KDCHERLI
Hey guys, just wanted to give you an update. It's fixed! I ended up cleaning out my iacv valve and now it runs great! :) Thx anyway
Jan 17, 2010 at 7:13 AM
KHLOW2008
  • 41,812 POSTS
Glad that you have solved your problem.
Cheers.
Jan 17, 2010 at 11:10 PM
