1989 Honda CRX timing advance
1989 HONDA CRX
250,000 MILES • 4 CYL • FWD • MANUAL
GCOUCH
recent overhaul on engine. before overhaul engine burned oil, replaced rings ,rod bearings, gaskets,reseated valves. engine runs well, fuel mileage 20+ no power. engine timing checked and no advance. what controls advance,ecu or other part. thanks gc what to check or replace? engine is 1.5 fi
Nov 8, 2009 at 8:29 AM
KHLOW2008
  • 41,814 POSTS
Hi gcouch,
Ignition timing advance is ECU controlled.
Is the ignition timing correct at idling?
Was the timing belt correctly installed and timed?
Nov 11, 2009 at 6:57 AM
