1989 Honda CRX Idleing
205,000 MILES • 4 CYL • 2WD • MANUAL
OKKRITIKOS
When my car warms up, It will idle at 1000 rpms. Then rev up to 1500 rpms then back down. About the same time this happened no heat comes out the defroster at the dash, and my air and heat blows very lightly. I dont know if that has to do with anything.
Feb 23, 2009 at 1:24 PM
KHLOW2008
  • 41,812 POSTS
Hi okkritikos,
Idling speed after warmed up should be 700.
The surging could be due to the electrical load problems. Check the alternator charging rate. Other problems might be related to this.
Feb 25, 2009 at 6:17 AM
1990HONDACRX
  • 11 POSTS
common question.. Its the TPS sensor on your intake manifold. It is supposed to regulate the idle off the intake manifold but has gotten wore out or gone bad.
The tps sensor is a funny thing to mess with and is usually rivited in to the throttle body so its hard to replace unless you remove the whole throttle body and drill out the rivits and replace with screws.
Throttle positioning sensor is the full term on tps.
If you look it up on photos in google youll be able to see when it is.
My crx did it before i changed over to full fuel injection and bought a new intake manifold and all new sensors.
It wont hurt the car and i know its annoying seince it constantly will rise and fall. If turning your heat and headlights down changes it then you might be able to up your idle alittle to reduce the chance the tps thinks it needs to be ajusted.
The throttle cable can be tightend by the two bolts and you can raise the throttle some to the point where it wont idle up and down but you get a idle of around 1200 rpms. If that dosent bother you go that way, or you can possible adjust your distributor forward some to get it to idle a little higher also.
TPS cost aroung 40$ on ebay and is easy to change if your confortable removing your throttle body. If you remove it, go for replaceing its gaskets. 12mm bolts all the way around and there is one bolt hidden under the whole intake setup witch will take you some time to work it off with a small socket wrench set up.
good luck
email me if you need any pointers, i have a few photos and can take some to give you a idea of what im takling about.
tyson_varrati@yahoo.com
Mar 22, 2009 at 12:07 PM
