1989 Honda CRX Fuel Pump
WOOD72IE
Electrical problem
1989 Honda CRX 4 cyl Two Wheel Drive Automatic
I have an 89 Honda CRX. What would cause the fuel pump not to come on? I have replaced the relay and the battery is charged. I removed the fuel pump and hooked it straight to the battery and it comes one. Once back installed it will not come on.
Aug 9, 2009 at 6:54 AM
  • 75,988 POSTS
Check if you have power to the injector yellow and black if not double check the PGM-FI main relay it powers the fuel pump and injector
Aug 9, 2009 at 7:20 AM
