1989 Honda CRX Fuel Problem
204 MILES • 4 CYL • FWD • MANUAL
ASHOUEKANI
I spray starter fluid into the throttle body and it starts up after a little effort and will run for about 5 minutes before stuttering and eventually dying.
Tested spark and have it. Possible clogged injectors? I have fuel to the filter.
Sep 21, 2009 at 6:00 AM
KHLOW2008
  • 41,812 POSTS
Hi ashouekani,
Test the fuel pressure. If it drops and engine stalls, it could be due to a failed fuel pump or PGM-FI main relay.
Sep 21, 2009 at 8:48 PM
