HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
CRX
Engine
Symptoms
Overheat
SPONSORED LINKS
1989 Honda CRX
ZAUCHEC
MEMBER
1989 HONDA CRX
1989 Honda CRX
I took out my a/c unit and heater> But my car is over heating and I cant figure out how to connect all the hoses correctly Please help
Monday, April 27th, 2009 AT 2:26 PM
F4I_GUY
MECHANIC
Which hoses did you take out? The heater hoses that contain coolant! If so, you should just loop them around.
You probably just have an air lock because you didn't properly bleed the coolant system.
SPONSORED LINKS
Sunday, May 3rd, 2009 AT 10:20 AM
Please
login
or
register
to post a reply.
Related Engine Overheat Content
1989 Honda Crx
89 Crx 1.6l 5 Speed Hf Hey I Had Got The Car 2 Months Ago In The Winter Time It Ran Good But 1 Day We Had A Really Bad Snow Storm And I Got...
Asked by
dt5988
1 ANSWER
1989
HONDA CRX
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
1987 Honda Crx Overheating....
Why Does My Car Overheat At Low/idle Speeds? A Couple Of Years Ago I Had A New Water Pump/timing Belt Installed And It Did Good For Awile...
Asked by
Hondacrx_87
1 ANSWER
1987
HONDA CRX
1990 Honda Crx Si Will Start But Wont After Engine...
Electrical Problem 1990 Honda Crx 4 Cyl Front Wheel Drive Manual My 1990 Honda Crx Will Start When The Engine Is Cool But Once It Gets...
Asked by
maunakane1
1990
HONDA CRX
After Over Heating, I Found The Radiator Drain Leaking Around The Solder Joint And After A Genital Tug Came Off. I Had The Repair Done On...
Asked by
aubreybarber
1 ANSWER
1987
HONDA CRX
Will Not Start
Car Will Not Start Replaced Distributor, Rotor, Battery, And Fuel Pressure It Good. Getting Spark, But Bc The Distributor Is 1989 And...
Asked by
Tabitha Simmons
1 ANSWER
1 IMAGE
1989
HONDA CRX
VIEW MORE
SPONSORED LINKS
Coolant Leak Symptoms
Online car repair manuals
