1988 Honda CRX shifting into gear.?
1988 HONDA CRX
175,000 MILES • 4 CYL • FWD • MANUAL
BST-INK
I can put my car into gear,and let the clutch out and it dosnt engage. but when you put it in each gear it seems alittle loose, i just picked this car up at a towyard.
you can see the plunger in the engine bay move around but.
Sep 3, 2008 at 3:47 AM
KHLOW2008
  • 41,814 POSTS
Hi bst-ink,
I believe the clutch is bad and needs to be replaced.
The loose gearshift is due to worn gear linkage bushes. You need to replace the linkage.
Oct 13, 2008 at 7:07 AM
