1988 Honda CRX No Heat
ZZZDOGMAN
Heater problem
1988 Honda CRX 4 cyl Front Wheel Drive 204000 miles
THis is an HF model in outstanding shape...preventive maintenance done (I've had it since new.)
During a trip to CA and back to CO last week, the heater suddenly began to blow cool air only, i.e., no gradual reduction in heat noticed indicating a heater core blockage. Changed the thermostat and visually inspected heater hoses to include the in-line temp selector valve for blockages--non found. Still no heat. Thoughts?
Jan 11, 2008 at 2:26 AM
BLACKOP555
  • 10,386 POSTS
since you say both heater core hoses are hot then you should check your blend door which is located in the air ducts. you probably have a bad electric motor or a bad vaccum line.
Jan 11, 2008 at 4:18 AM
