1988 Honda CRX HELP! HELP! HELP! No Brake Pressure!!
1988 HONDA CRX
200,000 MILES • 4 CYL • FWD • MANUAL
PROCRXSI88
Hey Everyone,
yesterday i started servicing my brakes it was in a really poor response.
i realised the brake piston was extreamly solid, so i took the front-right caliper apart. i took the brake piston out and cleaned the caliper, piston, lubricated the bolts of rust and sediments.
After i assembled everything back i test drived and hit the brakes hard and it was all fine.... bUT after i done the second one there was no brake pressure at all!!!!! I checked all 4 calipers there was no leaks of any kind.
I need help bad what do u think is wrong? Do i have air in my system or is it somthing worse....Thanks
Apr 3, 2009 at 1:42 AM
KHLOW2008
  • 41,814 POSTS
Hi procrxsi88,
Did you try bleeding the system?
Did you check the fluid level in master cylinder?
Apr 7, 2009 at 11:10 PM
DANIEL-CRX
  • 7 POSTS
change your master cylinder.
Apr 14, 2009 at 12:54 PM
WHEELMAN001
  • 8 POSTS
Bleed you system put new brake fluid in
My guess would be your master cylinder went bad
Jul 8, 2009 at 4:43 PM
