1988 Honda CRX ECU
1988 HONDA CRX
TJ FULLER
Electrical problem
1988 Honda CRX 4 cyl Two Wheel Drive Manual
just installed a rebuilt B18 from a 1991 Acura, most is built for horsepower but have a real issue with the idle surging from 800-1500 rpm. Checked the idle air valve and the ohms were within range. Could it possibly be the ecu located in the passenger area under the carpet. Thaks in advance!!
Nov 17, 2008 at 12:00 PM
KHLOW2008
  • 41,814 POSTS
Hi TJ Fuller,
I would suggest checking for vacumn leakages, coolant level, clogges coolant hoses to fast idle and IAC valve and faulty fast idle valve.
Nov 23, 2008 at 2:33 AM
