1988 Honda CRX 88 crx loss of power
161,000 MILES • 4 CYL • FWD • AUTOMATIC
SONAMY0310
Hi have an 88 crx, When I go to work no problems but when i go home problems, the engine bogs down, back fireing every now and then, i can pull over wait about 20 min start it up and drive again. I changed wires, plugs, cap and rotor. when this happens i can put it in park rev the engine and it is fine. checked timieing it is ok?
Oct 8, 2009 at 11:33 AM
KHLOW2008
  • 41,812 POSTS
Hi sonamy0310,
Since it is backfiring, the more likely cause would be the ignition coil since you have already replaced all other ignition components.
Oct 10, 2009 at 5:51 AM
