1987 Honda CRX Exhaust smell
250,000 MILES • 4 CYL • FWD • MANUAL
CONSV
Get strong exhaust smell when car is idling.
Won't pass emissions.
Car idle is a little squirelly and get vibration at 800 rpms so keep it at around 1000.
Car accelerates ok.
Have replaced dist cap, plugs, wires, injectors, fuel filter, air filter
Timing and valves have been adjusted.
Get number 1 light (drivers side) on ecu occasionally.
Getting around 30 mpg in mixed driving.
Any idea the cause of this?
Thanks
PS Forgot to add that the O2 sensor has been replaced too.
Jul 31, 2009 at 11:58 AM
  • 75,988 POSTS
Do you have a check engine light ?
Sounds like you're running on the rich side, check and test the following below
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode
Jul 31, 2009 at 12:22 PM
CONSV
Anyone know where the coolent sensor is located on this model?
Aug 13, 2009 at 8:44 AM
  • 75,988 POSTS
Civic 1500 (2) on cylinder head above thermostat housing and on engine block below intake manifold
Except Civic 1500 on rigtht side of cylinder head-Sorry no pic available.
Aug 13, 2009 at 8:54 AM
