1986 Honda CRX fuel problem
35,000 MILES • 4 CYL • FWD • MANUAL
POOLPLAYERPRO3
i have 86 civic crx, it has a new engine but will only run if i hold my hand over the back barrel on the carburetor. the moment i remove my hand it shuts off. what is going on with it? if i spray carburetor cleaner around the bottom of the carb it revs up do i need a new carb or mounting gasket? or do i just need to junk the engine?
Sep 26, 2010 at 4:19 PM
KHLOW2008
  • 41,812 POSTS
Hi poolplayerpro3,
You have vacuum leakages at bottom of carb. Remove the carb and check the gaskets. Replace if necessary.
Sep 27, 2010 at 8:16 AM
