I had a problem some time back with the car starting. If it sat for a while it would start fine. If I drove then a short later tried again I would have trouble. I got the car from my Dad who said that there was a problem with the fuel pump. The car sat for a while. I then replaced the fuel pump, screen, and fuel filter. There was plenty of fuel in the filter. Now the car will not start at all. I replaced all the spark plugs and still nothing. I took the filter off again and noticed there was little or no fuel in it. I believe it's not getting fuel to the engine. When I turn the key I hear the fuell pump engage about once every 20 or tries. What else should I look at? Could this still be a fuel pump problem or is there a relay of some sort that could be bad?
Jun 26, 2008 at 2:49 PM
