1985 Honda CRX
CANOBY
  • 1985 HONDA CRX
  • 4 CYL
  • FWD
  • MANUAL
  • 180,000 MILES
I have 2 questines one is it starts up fine and sounds good and revs good but when I give it gas it seems to lag no power then when I let up off gas it backfires from the rear and front I changed the sparkplugs and distributer cap and rotor it seemed to help it, could it be bad gas this problem didnt happen intil I filled my tank up at safeway gasstation in novato ca is that possible maybe I should drain the gas out of it and put fresh gas in 2 questine should u be able to turn fuel injecters by hand
Tuesday, December 9th, 2008 AT 1:06 AM
KHLOW2008
  • 41,814 POSTS
Hi canoby,
Yes, to the first question. Seems the gas is quite likely tobe the cause.
Yes again. The injectors are just clipped on with rubber bushes and O rings and if you twist them, they would turn.
Tuesday, December 16th, 2008 AT 9:17 AM
