1984 Honda CRX
1984 HONDA CRX
161,000 MILES • 4 CYL • FWD • MANUAL
JOECRX
i tried to give my dead battery a jump wen pit the cables they flash and the i lost power not theres nothing as far as power. do u have any ideas what i should do ?
i check all the fuse that were in sight, maybe there are others some were hidden
Dec 30, 2009 at 8:04 PM
KHLOW2008
  • 41,814 POSTS
Hi joecrx,
You have inadvertently connected the battery terminals incorrectly and most likely the main fuse is blown.
Check the main fuses in the underhood fuse box. Get a test lamp to test for voltage across the fuses, it would be more accurate.
Dec 31, 2009 at 10:15 AM
