I have been experiencing issues from the throttle body forward. I recently solved the p505 issue by cleaning out the idle air control valve but when I did that, the p1505 code popped up. Any ideas? I have taken the throttle body out twice since the new code popped up and don't know if it is something as simple as bleeding the coolant lines of all the air that I allowed in. When initially starting, it revs up to about 2,500-3,000 RPMs and then when put in gear it jumps from around 1,500-2,500 constantly but will jerk the car back and forth as it does so. It will accelerate by itself without any added gas, so I very much have to ride the brakes.
Jan 2, 2022 at 4:18 AM
