1997 Honda CR-V Ignition Key Won't Turn
RDELUCA2
I have a 97 Honda CR-V. The ignition lock has been giving me problems with the key turning. I've had to fiddle with it to get it to turn. Yesterday it just would not work. I had it towed to a service garage and they say I need a new ignition switch which sounds reasonable. They said it would cost about $500 including parts and labor. Does this sound reasonable? Thanks :(
Jan 22, 2007 at 8:40 AM
LOSONE
  • 1,616 POSTS
I think you will find there is a recall n most Honda ignition switches. Good Luck
Losone
Jan 22, 2007 at 9:13 AM
FIXITMR
  • 9,989 POSTS
see how much a lock smith wants!
Dec 12, 2010 at 12:48 AM
Suggested Repair
Check whether the 1997 Honda CR-V ignition switch is covered by a recall, and compare a locksmith quote with the shop's roughly $500 parts-and-labor estimate before replacing the ignition switch.
Conversation Summary
The owner of a 1997 Honda CR-V says the key has been hard to turn and then would not turn at all. A shop recommended a new ignition switch for about $500. Experts suggested checking for a Honda ignition-switch recall and comparing a locksmith's price.
