1999 Honda CRV ignition
176,000 MILES • 4 CYL • AWD • AUTOMATIC
JIM O'BRIEN
The key is not turning in the ignition at all times. Problem seems to be getting progressively worse.
Jan 17, 2010 at 2:39 AM
KHLOW2008
  • 41,812 POSTS
Hi Jim O'Brien,
The key cylinder is failing due to wear internally. Try some WD40 into the key slot to see if it helps. This is only a temporary fix and you would have to replace the key cylinder sooner or later.
Jan 20, 2010 at 4:25 AM
