Puts out black smoke when revving
80,000 MILES • 2.2L • 4 CYL • TURBO • 4WD • MANUAL
PAULYCOXY
When I rev my car it puts quite a bit of smoke out . only just started doing it. no codes on diagnostic. do you think it could be an injector?
It boosts good too.
Jan 25, 2020 at 8:54 PM
SCGRANTURISMO
  • 4,897 POSTS
Yes, it very well could be a fuel injector that is stuck open. Black smoke is usually a sign that too much fuel is being burnt by your engine. How are you managing your fuel or is the turbo stock?
Thanks,
Alex
2CarPros
Jan 25, 2020 at 9:34 PM
PAULYCOXY
Engine is standard mate, turbo stock.
There was quite a bit of difference between the mg delivery on injector 3 .
1..2...4 where around about 0.60 ...
Injector 3 was -1.9 ....
So something a bit wrong ...
Removed them for testing tomorrow .
Jan 25, 2020 at 10:02 PM
SCGRANTURISMO
  • 4,897 POSTS
Okay, how are you testing the fuel injectors? Do you have them on a flow bench? Usually you test fuel injectors with a Digital Multi-meter [DMM] and test the resistance across the terminals. You want to do this when they warm and then again when they are cold. Usually a high impedance fuel injector should have between 10 - 15 Ohms of resistance. Fuel injectors will usually fail when they get warmed up because the coils inside of them will expand with the heat a short out. You can usually see a difference in the Ohms from when they warm and then when they cool down. Please get back to us with what you find out.
Thanks,
Alex
2CarPros
Jan 26, 2020 at 12:12 AM
PAULYCOXY
I'm just going to put them into Delphi diesel mate . let them check them out ...
Will let you know what they find pal ...
Thanks
Jan 26, 2020 at 12:20 AM
  • 55,732 POSTS
I have seen a bad turbo cause this. can you remove the inlet or exhaust tube to check end play? Here are 2 guides to help us fix the problem:
https://www.2carpros.com/articles/how-turbo-chargers-work
and
https://www.2carpros.com/articles/engine-black-smoke
Please run down these guides and report back.Please let us know what you find. We are interested to see what it is.
Jan 29, 2020 at 1:25 AM
