2008 Honda CRV power socket
10,000 MILES • 4 CYL • FWD • AUTOMATIC
CLAVICLE
the power socket located below the gearbox stopped working...i was trying to troubleshoot it by checking the fusebox...apparently it doesnt appear that this particular power socket has a fuse associated with it...but i could be blinding...anyway, is there any other way to troubleshoot or repair this particular issue?..thanks!
Nov 28, 2008 at 6:49 AM
F4I_GUY
  • 3,302 POSTS
You can check if you have power going to the socket (you most likely wont)
There is a fuse for it. Usually what I do is I check all the fuses with my test light or fuse tester. On a 2008 I can't see it being anything beside a fuse.
LMK what you find.
Dec 2, 2008 at 9:16 AM
