2008 Honda CRV CRV BOOT
10,000 MILES • 4 CYL • AWD • AUTOMATIC
DANIEL SEMIC
i took my CRV in for a service and was told it needed a CRV boot replaced. It's covered under warranty but someone told me that I should have the whole axel assembly replaced because the tear in the boot may have compromised the joint. is this necessary?
Sep 19, 2008 at 7:57 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:2b8c870d72="Daniel Semic"]Transmission problem
2008 Honda CRV 4 cyl All Wheel Drive Automatic 10000 miles
i took my CRV in for a service and was told it needed a CRV boot replaced. It's covered under warranty but someone told me that I should have the whole axel assembly replaced because the tear in the boot may have compromised the joint. is this necessary?[/quote:2b8c870d72]
Honestly, I would have them replace the CV Axle. If the CV Boot has a split it is possible for dirt and contamenants to get into the CV Joint Grease and start to wear down the bearings.
You may have to fight a little with them since it is under warranty they usually like to do things the cheaper way.
Sep 19, 2008 at 8:13 AM
