will not come on upon opening right front door, all other doors operation ok
Jan 10, 2009 at 8:52 AM
KHLOW2008
✓Experienced Mechanic
Hi Garry,
The problem should be with the door switch. Check the door switch contact and some sanding down might be required to get it working. Remove the switch and ground the wire to see if the light works.
