2007 Honda CRV chaning oil code
2007HONDACRV
Computer problem
2007 Honda CRV 4 cyl Front Wheel Drive Automatic
i changed my oil from jiffy lube and the code on my crv computer the same tell me how to reset it!!
Aug 21, 2008 at 1:38 PM
KHLOW2008
  • 41,812 POSTS
Hi 2007hondacrv,
You need to reset it manually after oil change.
With ignition switch in 'OFF' position, press SELECT/RESET button and turn ignition switch "ON". (DO NOT start.)
Keep SELECT/RESET button depressed for about 10 seconds until indicator resets.
Aug 22, 2008 at 1:27 PM
