2006 Honda CRV shaking at RPMs under 2
2006 HONDA CRV
VEORNICA HOLETON
Shakes or Wobbles problem
2006 Honda CRV Automatic 63,000 miles
After my car has been idle overnight or during work, it tends to run shaky, vibrating like I'm running on a rough road. This only at low RPMs under 2 and speeds under 40mph. It never happens on the freeway. If I just lift my foot off of the accelerator, the shaking stops.
Dec 10, 2008 at 5:34 AM
KHLOW2008
  • 41,814 POSTS
Hi Veronica,
The symptoms described does not give much for us to work on so I am going to ask a few questions to understand the problem better.
1. You mean the problem happens when starting from cold only?
2. Does it go away after the engine is warmed up?
3. Do you have the Check Engine Lamp showing while driving?
4. Have you checkd the spark plugs and related parts?
Dec 30, 2008 at 12:52 AM
