Front end vibration when brakes are applied
BELLJMSBLL
Brakes problem 4 cyl All Wheel Drive Automatic 21,000 miles
Front end vibrates and steering wheel vibrates when brakes are applied at 70mph+. Does not happen at 60mph. Suspect problem caused by ABS.
Apr 23, 2008 at 2:37 AM
  • 55,688 POSTS
I would more so suspect that the rotor or rotors are warped. Turning them will probably not fix it but replacing them will, Job is very easy to do.
Here is a guide that will help you get the problem fixed.
https://www.2carpros.com/articles/steering-wheel-shakes-when-accelerating-or-braking
Best, Ken
Apr 4, 2017 at 8:23 AM
