2005 Honda CRV Steering Noises/Vibrations
OLSONAH82
Noises problem
2005 Honda CRV Four Wheel Drive Automatic 43900 miles
I was recently in a minor fender bender--car from behind hit me in the right rear area of car. I took it into the dealership to make sure nothing was damaged, and they could not find anything other than a broken mud guard.
As fate would have it, that evening I began to hear griding noises under the floorboard when I turn left, and then heard major humming/vibration from the exhaust area or just in the rear of the car.
I don't know if it is my mind playing tricks, but would like advice. The dealer could not find anything wrong, but want a second opinion.
Thanks.
Nov 5, 2009 at 5:40 AM
F4I_GUY
  • 3,302 POSTS
The humming/vibration sound could be from the broken mudguard riding against the tire. Ensure nothing is touching the tire. If that checks out, check your drivetrain (u-joints, differential, wheel bearings)
Nov 6, 2009 at 8:55 AM
OLSONAH82
I took it to the dealer, and they replaced the mudguard. The next day is when the noises started. So, I took it to a local Firestone, they put the CRV up in the air, and showed me that my muffler got impacted, which I guess caused a domino effect with my axle?? They said no structure damage was caused, just the muffler will make noise now. Does that sound right? I do plan on replacing the muffler.
Nov 11, 2009 at 2:57 AM
BONESS1
OK THAT SOUND AND VIBRATION IS CAUSED WHEN U MAKE TURN OR HARD TURN CORRECT? THATS FROM YOUR REAR DIFFERENTIAL,WHICH MAY BE DAMAGED INTERNALLY BY ACCIDENT. ITS IN THE MIDDLE OF BOTH AXLES.IT MAKES THAT NOISE AND FEELIN WHEN UR FLUID NEEDS DRAIN AND FILLED CUZ ITS CONTAMINATED..BUT SINCE THE ACCIDENT IT MAY NEED REPLACED..IM A HONDA TECHNICIAN
Dec 7, 2009 at 1:51 PM
