2005 Honda CRV noise in turning sharp at slow speeds
37,000 MILES • 4 CYL • 4WD • AUTOMATIC
HONDADRIVER3
just wandering if any other owner like tbone-fireball
found out solution to similar problem.
Nov 13, 2008 at 2:30 PM
KHLOW2008
  • 41,812 POSTS
Hi hondadriver3,
Seems you are having a problem with the differentials.
There was a Technical Service Bulletin on this and you should contact the nearest Honda dealer to verify if you are entitled to a warranty on the case.
Likewise, an oil change of the rear axle differential might solve the problem. You should ONLY use the specified Honda DPSP trans fluid.
Nov 22, 2008 at 10:05 PM
GLENVILLE
If the noise is severe, the probability is it is the diff. A mod.repair kit will need to be fitted. I hope this solves your problem, cheers
Mar 8, 2009 at 4:19 AM
