IAC Location
22,000 MILES • 4 CYL • 4WD • AUTOMATIC
CARMANMT
  • 19 POSTS
Hi, can anyone help me find the IACV? I searched around and cannot locate any information on where it is located on the vehicle.. Thanks
Dec 29, 2008 at 6:53 AM
KHLOW2008
  • 41,812 POSTS
Hi, I managed to get a pix of the throttle body and IAC. The IAC is attached to the lower part of the throttle body
https://images.2carpros.com/forum/automotive_pictures/192750_ThrottleBody02CRV_1.jpg
Jan 8, 2009 at 4:34 AM
CARMANMT
  • 19 POSTS
Great, thanks a million.. I saw that but was reluctant to tamper with it..
Jan 10, 2009 at 2:41 AM
KHLOW2008
  • 41,812 POSTS
Hi carmanmt,
What is the reason you want to fiddle with it?
Jan 10, 2009 at 2:52 AM
CARMANMT
  • 19 POSTS
I was going to clean it because in one of my original post someone recomended that because I was getting poor gas mileage..
Jan 19, 2009 at 1:54 PM
KHLOW2008
  • 41,812 POSTS
If the idling speed ia erratic then it could cause high fuel consumption but if the idling speed is correct, the IAC is ok. You can clean by spraying carb clreaner into the lower port of the throttle body which is into the IAC. Let it soak and wait for the carbcleaner to dry out before attempting to start.
I normally uses spurts when spraying with engine running and air cleaner hose off. Try to rev the engine slightly to prevent it from stalling.
Jan 20, 2009 at 12:09 AM
CARMANMT
  • 19 POSTS
KHLow2008, Thanks for the tip.. I will give it a try and let you know..
Jan 21, 2009 at 12:00 PM
