2005 Honda CRV Coolant Leak
40,000 MILES • 4 CYL • 2WD • AUTOMATIC
FMSEVILLA
The coolant in the reservoir gets lost and there is no wet spot on the garage floor. Had the reservoir, water pump and radiator checked. The reservoir, water pump and radiator have no leak. Loses almost 1 liter of coolant in a week. What could be the cause?
Sep 20, 2009 at 11:56 PM
KHLOW2008
  • 41,812 POSTS
Hi fmsevilla,
There definitely is a leak somewhere and a pressure test should be performed to find the source.
Check the radiator cap seals condition.
Check if the heater core is leaking.
Sep 22, 2009 at 6:39 AM
