Engine Performance problem
2005 Honda CRV 4 cyl All Wheel Drive 73000 miles
I-VTEC 2.4 DOHC engine.
At about 40~45 mph, 1250~1450 rpm my car shudders like it can't make up it's mind which gear it should be in.
Honda Dealer said it could be the EGR Valve or Torque converter.
They suggested removing the wires from the EGR Valve, drive it & see if that stops the problem, but do not plug wires back in while it is running.
Where can I find the EGR Valve? Internet search has not helped. If this is the problem, can I remove, clean it & reinstall the valve?
Thank You for any help.
Nov 6, 2009 at 7:21 AM
