2004 Honda CRV Windows
2004 HONDA CRV
100,000 MILES • 4 CYL • AWD • AUTOMATIC
ADRIENNE528
While on the driver side, if I go to push the window switch to go down on any of the windows it will not go down when it is hot outside. However, if it cools down outside the windows will go up and down freely. Recently I am unable to put down the back, right, rear window from the drivers side. However, anyone sitting on the right, back rear window can push the button up and down. Overall, if it is hot outside the windows will not go down from any switch. I checked all the fuses in the car and under the hood and I have not seen a problem. What could be the cause of this, is it a relay switch? or a short in a wire somewhere?
Aug 11, 2010 at 9:38 AM
KHLOW2008
  • 41,814 POSTS
Hi adrienne528,
Problem is more likely to be from the mastrer switch and/or Multiplex control system.
If you can get a master switch to test, that might save you a lot of time.
Aug 12, 2010 at 3:15 AM
