Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
CRV
Drivetrain
Transmission
Gear Selector
2004 Honda CRV VEHICLES STARTS GEAR SHIFT STAYS IN PARK
2004 HONDA CRV
27,000 MILES • 4 CYL • 2WD • AUTOMATIC
BEAGLE52
MEMBER
1 POST
IS THIS A COMPUTER PROBLEM. THE SWITCH UNDER THE BREAK PEDAL WHICH IS WHITE DOES RELEASE. BUT VEHICLE WILL NOT GET OU OF PARK?
Apr 13, 2008 at 10:48 AM
BRUCE HUNT
Experienced Mechanic
If what you say about the switch is correct, then replace the solenoid located on the shifter lever.
Apr 25, 2008 at 3:06 AM
KHLOW2008
The brake switch operates but does the brake lights come on? If not you might have a blown stop light fuse or wiring problem.
May 26, 2008 at 3:12 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
