2004 Honda CRV VEHICLES STARTS GEAR SHIFT STAYS IN PARK
2004 HONDA CRV
27,000 MILES • 4 CYL • 2WD • AUTOMATIC
BEAGLE52
IS THIS A COMPUTER PROBLEM. THE SWITCH UNDER THE BREAK PEDAL WHICH IS WHITE DOES RELEASE. BUT VEHICLE WILL NOT GET OU OF PARK?
Apr 13, 2008 at 10:48 AM
BRUCE HUNT
  • 3,754 POSTS
If what you say about the switch is correct, then replace the solenoid located on the shifter lever.
Apr 25, 2008 at 3:06 AM
KHLOW2008
  • 41,814 POSTS
The brake switch operates but does the brake lights come on? If not you might have a blown stop light fuse or wiring problem.
May 26, 2008 at 3:12 AM
