2004 Honda CRV removal and installation
2004 HONDA CRV
52,850 MILES • 4 CYL • 2WD • AUTOMATIC
CLEAN MACHINE
Need to know how to change the expansion vavle and the desicant bag in the receiver dryer and where is the dryer
Jul 14, 2009 at 5:21 AM
STEVEW84
  • 673 POSTS
To Replace Reciver/Dryer/Desicant Bag
1.Remove the condenser
2.Remove the cap (A) from the bottom of the condenser, then remove the O-ring (B), the filter (C) and the desiccant (D).
3.Install the desiccant in the reverse order of removal, and note these items:
Replace the O-ring with new ones, and apply a thin coat of refrigerant oil (KEIHIN SP-10) before installing them.
Be sure to use the right O-ring for HFC-134a (R-134a) to avoid leakage.
Can't find anything on expansion valve or orifice. Don't know what they are using. HTH
Jul 16, 2009 at 2:02 PM
