2004 Honda CRV noise or vibration while turning
2004 HONDA CRV
DLMCCLEAN
Noises problem
2004 Honda CRV 4 cyl All Wheel Drive Manual 80k miles
recently changed brakes on all 4 corners. Same weekend, took the vehicle to the snow for the first time, using the all wheel drive. Now, when I turn sharply either left or right, vehicle makes kind of grinding noise or vibration. Braking and everything else appears fine when driving straight, only sharp turns
May 6, 2008 at 3:58 AM
KHLOW2008
  • 41,814 POSTS
When was the last time you replaced the rear axle oil? This is a high pressure oil which have a life span of about 60,000 km (32,000 miles) and will cause vibrations when turning.
May 26, 2008 at 2:28 AM
