Heater does not work
50,000 MILES • 4 CYL • AWD • AUTOMATIC
TOMMYBOYINK
heater does not work, looking for advice on fix and repairing it???
Thanks
Tommy W
Mar 23, 2009 at 5:29 AM
F4I_GUY
  • 3,302 POSTS
Well check the fuses first.
If the fuses are fine, check if the blower motor is receiving a power and ground signal when the blower fan is turned on.
Check out this guide
https://www.2carpros.com/articles/car-heater-not-working
Mar 25, 2009 at 10:18 AM
DONLYTTON
  • 0 POST
Thank you for this post the guide showed me the thermostat was bad got anew one for $46.00 all fixed!
Sep 24, 2019 at 12:38 PM
JOTHMER
  • 5 POSTS
My Honda CRV is not blowing out hot air. It's been flushed and changed the heater core but still no heat.
Sep 24, 2019 at 12:39 PM (Merged)
KHLOW2008
  • 41,812 POSTS
Was the thermostat checked? Was the system bled of air? This guide can help.
JOTHMER
  • 5 POSTS
Yes on both. Got a little heat on low setting after the heater core was replaced but not anymore.
KHLOW2008
  • 41,812 POSTS
Are both hoses to and from the heater core hot?
JOTHMER
  • 5 POSTS
no one is hot and the other cold
KHLOW2008
  • 41,812 POSTS
This indicates coolant is not flowing and it could either be due to clogging of the heater core or the hoses are not installed correctly.
It could also be due to the thermostat sticking in the open position or a weak water pump.
When flushing the heater core, were the flushing water coming out strongly?
SK8PAT777
I have an 02 Honda CR-V with about 81k miles.
For 2 months now, my heater and AC have not been working. All fuses seem fine, never had a problem before. Air does not even blow out.
When I have it in outside air mode the air comes, of course, and at the correct temp I set it to, if I am making sense.
Need help before I buy parts and replace, any diagrams, info is MUCH appreciated!
Thank you!
DAVE H
  • 13,383 POSTS
How to Retrieve a Diagnostic Trouble Codes The Heater Control Panel has a self-diagnosis function. To run the self-diagnosis function, do the following: Turn the ignition switch OFF. Turn the fan switch OFF, the temperature control dial on Max Cool and the mode control dial on Vent. Turn the ignition switch ON (II), then press and hold the recirculation control switch. Within 10 seconds while holding the switch down, press the rear window defogger switch five times. The recirculation indicator blinks two times, then the self-diagnosis will begin. If there is any problem in the system after self-diagnosis is finished, the recirculation indicator will blink the Diagnostic Trouble Code (DTC) 7 through 13. When problems in the evaporator temperature sensor circuit are detected (codes 14 and 15), the A/C indicator will blink the DTC. If no DTC's are found, the indicator will not blink. Fig. 7: Retrieving DTC Courtesy of AMERICAN HONDA MOTOR CO., INC. Fig. 8: Example Of DTC Indication Pattern (DTC 7)
https://images.2carpros.com/forum/automotive_pictures/266999_dtc_3.jpg
https://images.2carpros.com/forum/automotive_pictures/266999_dtc2_3.jpg
Canceling the Self-diagnosis Function Turn the ignition switch OFF to cancel the self-diagnosis function. After completing repair work, run the self-diagnosis function again to make sure that there are no other malfunctions. Max Cool Position Function When the mode control dial is in the MAX A/C position, the heater control panel will automatically select the Recirculation mode and turn the A/C on. The recirculation switch and A/C switch are disabled and cannot be turned off in this mode. If the control panel fails to function as described, replace it.
https://images.2carpros.com/forum/automotive_pictures/266999_dtc3_2.jpg
https://images.2carpros.com/forum/automotive_pictures/266999_dtc4_1.jpg
JOTHMER
  • 5 POSTS
yes the water had good flow
KHLOW2008
  • 41,812 POSTS
If the water had good flow, then it should not be a clogged heater core. Check the hoses for clogging.
JOTHMER
  • 5 POSTS
already been checked and replaced heater core
KHLOW2008
  • 41,812 POSTS
Recheck the thermostat, ensure it is not sticking in open position. Remove radiator cap and while running note if the coolant are circulating when engine is cold.
THRITYSHARK
Air Conditioning problem
2002 Honda CRV 6 cyl All Wheel Drive Automatic
I started my Honda yesterday and have absolutely no fan, for the heater or the air conditioner. We had the entire A/C unit replaced last summer. I checked the fuses and cannot find one that seems to be blown. Is this a belt issue?
KHLOW2008
  • 41,812 POSTS
Hi thrityshark,
If the blower fan is not working, it most probably is caused by a failed motor.
Give the housing under the dash some gentle banging with your fist to check if the motor starts running, if yes, the motor is due to be replaced.
MICHAS
2002 Honda CRV 4 cyl Four Wheel Drive Automatic 135k miles
I have had icecold air until yesterday when at a stop light the aire was luke warm. as I accelerated the air cooled off and was ice cold again until I stopped. Could this be a belt problem or is it a serious AC problem?
F4I_GUY
  • 3,302 POSTS
When you are stopped at a light put the vehicle into neutral and revv it up, does the incoming air get colder?
And yes this is an a/c problem. I've seen loose belts and low refrigerant cause this.
CMSIDUR
My car's heat is not hot but warm. I thought it just needed to warm up like most cars but as the days get colder so does the car. It used to take about five minutes to get hot but now its just warm. Can anybody help me with this problem?
  • 31,937 POSTS
Hi there,
Thank you for the donation,
Check that the heater hoses coming from the engine into the cabin are both hot to touch with the heater on and engine at normal operation temp. if not, you have no flow through the heater core, this may be due to a blocked core or a faulty heater tap, check this out first.
mark (mhpautos)
SHICKSHEN
Related to this thread, my 2001 Honda CRV had its radiator replaced a year ago. All fine, and cooling system does what its supposed to do now, but the heater just started only blowing cool air. Any ideas on how to diagnose?
Aug 23, 2023 at 4:19 AM
  • 55,649 POSTS
Yes, it sounds like an air bubble is stuck in the heater core, I would get the engine warm then park the car on a steep incline (front down) and turn the heater on full blast to help get the bubble out. Also try turning the car around the other way as well. I have seen people use a jack to simulate the slope also.
and
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Check the coolant level after the engine has cooled after the procedure to see if the level has dropped. Please go over these guides and get back to us.
Aug 24, 2023 at 3:58 AM
