2004 Honda CRV For those who love a challenge
2004 HONDA CRV
115,000 MILES • 4 CYL • 2WD • AUTOMATIC
SEBERWEIN
Car: 2004 Honda CR-V 2WD, Automatic 1 owner, 115K miles
Here are the symptoms:
-Heater doesn't get hot
-Air comes out of engines when oil cap is removed
-2 radiator fans won't turn on
-overheats after about 10 mins when idle, but not when driving
-white smoke comes out of tailpipe
-car shakes really bad when 1st turned on & for first ½ mile of driving
-radiator slowly leaks when driven
-sometimes engine won't turn on at all even when cooled down
-smell of antifreeze
What's been done – I've gotten three estimates w/ three totally different opinions of what's wrong
The radiator was replaced 2 months ago
Radiator coolant fan was replaced 2 mths ago
There is no water in the oil
Thermostat is working
No Fuses are blown
May 17, 2008 at 11:55 PM
LEGITIMATE007
  • 5,121 POSTS
well first your engine coolant temp sensor sounds like its shot, the smoke is probably oil not coolant. only diference is oil has a slightly blueish tint. also when the coolant was refilled was the system air blead? there is probably an air pocket in the system. thats why its not blowing heat
May 18, 2008 at 12:03 AM
SEBERWEIN
Smoke is definitely white, no bluish temp and the oil level is remaining fairly constant, i'm not losing oil. no sure if it was air blead, it was done by a auto repair chain
May 18, 2008 at 12:15 AM
