2004 Honda CRV coil replacement
2004 HONDA CRV
79,000 MILES • 4 CYL • 2WD • AUTOMATIC
MARTY SPURLOCK
I need directions on how to replace the coil on the compressor. the coil is bad and needs to be replaced. it will not allow the clutch to engage.
May 19, 2008 at 7:23 PM
2CARPRO JACK
  • 11,533 POSTS
Remove center nut, then remove armature plate,careful not to lose the shim/shims .Remove snap ring and remove rotor pulley.there is one more snap ring and the field coil will come off, reverse for reassembly
May 20, 2008 at 3:21 PM
