2004 Honda CRV AC/Heater blower switch
SBENTZ
Air Conditioning problem
2004 Honda CRV 4 cyl All Wheel Drive Automatic 70k miles
The blower motor for my AC/heater stopped blowing. I took out the blower and tested it with an external power source- it worked fine. I can't find any fuse to blame for the problem either. I tested the lead going into the fan and it appears to register a voltage... Am I dealing with a bad switch or maybe a blown relay? And is this a "home-fixable" problem ?
Sep 13, 2009 at 2:24 AM
F4I_GUY
  • 3,302 POSTS
How much voltage did you get at the blower motor? Also, did you check the ground side of the circuit?
Sep 18, 2009 at 10:53 AM
SBENTZ
[quote:dff7047cf1="F4I_guy"]How much voltage did you get at the blower motor? Also, did you check the ground side of the circuit?[/quote:dff7047cf1]
I don't remember the voltage- but I solved the problem with a replacement blower motor resistor.
Sep 21, 2009 at 12:18 AM
