2004 Honda CRV ac will not work
93,000 MILES • 4 CYL • 4WD • AUTOMATIC
DAVID4825
Blower motor will not work.Took motor out and hooked to battery with jumper wires and works great. All controls indicator lights appear to be working but compressor does not run.Could it be the relay or resistor and where are they located. Thanks for you help david
Jul 8, 2010 at 7:03 AM
KHLOW2008
  • 41,812 POSTS
Hi david4825,
Did you check fuse # 14 ( 10 A ) in under dash fuse box?
Jul 13, 2010 at 2:19 AM
DAVID4825
I checked all fuses and it turned out to be the blower motor resistor. Replaced it in about an hour and all is well. Thanks for your help.david
Jul 13, 2010 at 3:43 AM
KHLOW2008
  • 41,812 POSTS
The highest speed should have been working and you did not mention that.
Glad to know you have fixed the problem.
Have a nice day.
Jul 13, 2010 at 5:39 AM
