2003 Honda CRV whining noise
CHRISHARRINGTON
Noises problem
2003 Honda CRV Four Wheel Drive Manual
When travelling approx 70+ mph and when weight is on the right hand side , whining noise cuts in when pulling, and stops when you take the throttle off.
10/22/08
Thanks very much for your answer to the Honda CRV whining noise question, my husband was most impressed with your diagnosis.This in itself is an amazing feat!
Thanks once again,
Oct 6, 2008 at 4:46 AM
KHLOW2008
  • 41,812 POSTS
Hi chrisharrington,
You are gettting noise from the trans and I would suggest checking the trans oil level first. If oil level is correct, one or more of the trans bearing is going bad.
Does the noise appear in 4ht gear at a lower speed? If no, then the 5th gear is the problem.
Oct 14, 2008 at 6:24 AM
