2003 Honda CRV Vibrates between 25-40 MPH - Intermittant
82,000 MILES • 4 CYL • 4WD • AUTOMATIC
REBT101
I am having the same problem as a previous post on 12-3-09 where my CRV shakes/vibrates occasionally on a level surface between 25-40 MPH. If I let up on the gas or excellerate the noise immediately goes away. I also have a 03 Odyssey that does the same thing. The Honda dealer can't get it to make the noise but they replaced a 3rd clutch pressure switch for a flashing D light. This didn't help. They say they can't do anything without feel the vibration.
Jan 14, 2010 at 2:18 AM
KHLOW2008
  • 41,812 POSTS
Hi rebt101,
Thank you for the donation.
If the vibrations only occurs during light acceleration, there most likely cause would be the drive trains.
I would suggest checking the CV shaft inner joints for excessive side play , worn rubber boots and spilt CV grease around them.
The other item to check would be the propeller shaft. If the U joints are stiff or worn, vibration would occur at the speed mentioned with light acceleration.
Jan 15, 2010 at 3:15 AM
